Before pics a few posts back. Got the idler shaft and bearings
back in after welding it all up. Fingers crossed on that.
Installed a new hydraulic pump while top was off. ( that was
the reason I took the top off to start with) . To install pump i
remove the cylinder bolts, and sorta just moved the cylinder
down for pump installation clearance with unhooking any
linkages. When I put the top back on, I have steering and can
see the hoses jump when I move a valve lever but the 3-pt
lever only travels half way and the oils gets so hot in five min
you cant touch the filter housing. Could those linkages
gotten crossed up? Ill provide a pic of the unit as it sets now
with hydra-lectric top removed. The 3-pt lever binds itself at
the halfway up point. Does anyone have a pic of this. I can
find one.
find one.
