super99
The lift arms on my 1850 settle down as soon as you shut it off. The 3 pt works as it should when running, so the seals on the piston are good and the elbow isn't broke off. The arms stay where you set the lever when it's running, just settles down when shut off. I have to take the hydraulic off to replace a broken bolt under the rockshaft and while I'm in there I would like to fix whatever inside holds the arms up when it is shut off. Anyone know what it's called or a part number?? I've been around Oliver's since 1973 and know that the arms are supposed to stay up when tractor is not running. I have 2 1550's, one the arms stay up and the other doesn't. It will be next after the 1850 to get fixed if I can find out what the part is called. The first 1850 that I bought in 1973 the arms would settle down when I looked at it. My brother told me they were supposed to stay up, so I got the dealer to fix it before I bought it and they stayed up as supposed to for as long as I had the tractor. Thanks, Chris
