I pulled the exhaust manifold yesterday and found that cylinder 2 is puffing white smoke. I went ahead and pulled all of the injectors and took them to the local injector shop and had them cleaned, tested and set to the same psi. After re-install the tractor still smoked from cylinder 2. I also swapped injectors from 2 and 6. After that exercise I pulled the valve cover and adjusted all of the valves. Most of them were at .028 and I adjusted them all to .030. Still the same results. I would like to do a compression test but I am not sure where to get the correct fittings? I have heard of people gutting an old injector to make it work. Does anyone have info on what to use. Also any other ideas to help a cylinder out? I am guessing it is a compression issue.
