310 front pulley wear sleeve
CDN 400
Does anyone know the part number for the wear sleeve that goes on the front pulley for the front main seal? I looked on agco parts
but can't find it. This is a late cooler block 310 if it makes a difference.
https://www.skf.com/ca/en/products/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve
Not aware that agco sold these. Just mic your pulley and you can probably have Amazon deliver one to your door. Better option (in my opinion) is to just set your seal in a differnt spot when pressing in to your housing.
Thanks Tom, I'm getting an aftermarket one from my machine shop. I just figured agco would have them same as the rear but no and beings it had one on it figured I would just replace it.
