[b:51c76b5b19]Hi,
I have been tractor pulling for a couple years now, usually in small local pulls. I run a Farmall M in the 6000-7000lb class and a Farmall Super M in the 7000-8000lb class. My Super M weighs 7750lb and the M is at 6450 lbs. I'M generally pretty competitive in these classes.
I went to a big pull this weekend and got my A#% kicked pretty bad. All the Farmall Ms were in the 5-6000 lb class and I was pulling against JD 620's and 630's and Cockshutt 50's. I got smoked!! So my plan is to drop the M into the 5000-6000lb class. All of these tractors are bone stock. What classes do you guys pull your Super M's and M's in??? What do you pull against?? How do you usually make out??
Thanks,
SW6[/b:51c76b5b19]
Thanks,
SW6[/b:51c76b5b19]
