Anonymous-0
No it isnt mine or martys . But I have to have one . Rumor has it theys a hemi headed one in hotlanta.
ttp://www.profilerperformance.com/bbford-205.html(quoted from post at 17:36:30 04/26/11) You should just get you one of those mercuriser ford 4cyl.They have lots of head options.
CHRYSLER GUYS ARENT LEFT OUT EITHER(quoted from post at 17:51:38 04/26/11)ttp://www.profilerperformance.com/bbford-205.html(quoted from post at 17:36:30 04/26/11) You should just get you one of those mercuriser ford 4cyl.They have lots of head options.
Intake Port Flow: 524 cfm@ .900 with 2.450 valve
(quoted from post at 18:05:55 04/26/11)CHRYSLER GUYS ARENT LEFT OUT EITHER(quoted from post at 17:51:38 04/26/11)ttp://www.profilerperformance.com/bbford-205.html(quoted from post at 17:36:30 04/26/11) You should just get you one of those mercuriser ford 4cyl.They have lots of head options.
http://www.allpar.com/mopar/la4.html
GOOD ARTICLE. I still like the 100 cubic inches per cylinder better than small cubic inches for pulling but I do however like the heads, better flow, needle bearing cam bearings t&e or jessel rocker arm technology spring technolgy etc along with ,injection, crank trigger firing single coil pack to plug and alot of the other midget technology . But for the guys who think high winding little engines are the ticket 9500 rpms will definately have wheel speed.(quoted from post at 14:48:48 04/27/11)(quoted from post at 18:05:55 04/26/11)CHRYSLER GUYS ARENT LEFT OUT EITHER(quoted from post at 17:51:38 04/26/11)ttp://www.profilerperformance.com/bbford-205.html(quoted from post at 17:36:30 04/26/11) You should just get you one of those mercuriser ford 4cyl.They have lots of head options.
George Poteet's land speed record '69 Cuda "Blowfish" ran one those Mopar Midget motors. Its was 175ci and made 1000hp, with the help of 20-30psi of boost and EFI.
That might be a little hard to get past some tech inspections if that was crammed into a WD.
http://www.hotrod.com/featuredvehicles/113_0702_1969_barracuda/photo_16.html
I guess your going to trade me that 6.5 for a stock stroke crank since you've been poisoned to believe little strokes are better. Awaiting you to deal to pay shipping and trade will be final. I should get boot if you really believe bs poision.(quoted from post at 18:56:04 04/28/11) please dave, dont feed his ego
(quoted from post at 20:29:10 04/27/11) Mitch no disrespect to you. Where do you guys pull these high rpm engines with all of the power at. I think that they would be very interesting to watch. The best pulling tractor that I have seen in Division 4 at that weight class would be Justin Monroes Farmall H its only allowed to pull 20% over.
