Ok so I'm looking into Pulling in a stock class and they allow tire cutting. Not full cut though and I have a tractor that I want to use that has tires with about half the tread left on them. Should I just pull it the way it is or should I try and cut them? I seen one guy said the older and harder the better so I would like to use them. The lugs are just a little rounded off though. I wasn't sure if that would hurt performance. The rule as written says " No full cut tires allowed. No restrictions on top of lugs. Must be a distinguishable line at back of lug befor the casing." I'm just worried that if I "cut" them they will say I messed with the front of the lug.
Thanks for your help and patients with a newbie!
