How would a person go about determining the amount of down force on the hitch in a given weight class, when the only variable is the speed in which the weight box climbs the sled?
Or how do you arrive at the amount of weight on the front of the tractor? I know there are some precentages that people use. My puller is balanced
( front just floating ) until I hit the 8500 lb class and then with the weight all the way forward the front comes way up, at the half way point the front is off the ground high enough that I cannot control direction unless using the brakes.
