Oliver 88 diesel approximate weight.
crl800
Can someone give me their best guess on how much super 88 diesel would weigh? Narrow front, cast wheels, 14.9 coop tires, hydraulics and PTO. Want to pull in 5000 and up. Not sure if it will make it with a driver.
My S88D set up just as yours is around 5,300# which includes a 200lb driver. So you'll need to lose some pounds to get to 5000#. If you want to keep the hyd and pto you'll need to go pressed steel on back wheels and/or 66 narrow front end assembly.
Std. hubs, tin wheels front & rear, no belt pulley, flat top trans cover, weight brackets & wheelie bars, I am 4210
without driver.
