Well it's a little early to write this now as it's only been 4wks for the first eye and 3wks for the second eye. Since there's a current question on the subject, I decided to go ahead and post my results.
WOW, WOW again, as I've worn glasses for over 50yrs and now don't need glasses for any distance or puter usage. I lost my great close-up vision that I had, about 6" away without any aids. NO night time halo's or stars. It appears that I may be "sun" sensitive, so I need sunglasses.
I went thru 3 eye Doc's in 2yrs before finding my current eye Doc. One was bait & switch, told me I'd have 20/20 "if" the eye was capable of 20/20, then told me the day before surgery it would cost me another $2200 plus the original fees, for each eye, too see 20/20. I walked out "bitc*ing" to say the least.
Two eye Doc's, I didn't get that warm and fuzzy feeling that I thought that I should have. Again I walked away.
Then I found Dr Perkins in Mesa Az. Over 40,000 cataract surgery's and in his prime, about 45yrs old. Excellent very well educated staff. They have there OWN surgical staff and buildings, that's 4 buildings total, so as you can see, they do alot of eyes. About $600/eye total, my cost with only having Medicare A&B.
My right eye was blind from the cataract. I was told to wait until the cataract matured but no body defined "mature", so I went blind waiting. Dr Perkins says that you only need to wait until the cataract bothers your vision until you get them removed. This is due too new procedures, materials and equipment. Dr Perkins stated that I'd be lucky too see the big "E" on the chart. I can read line 6 on the chart. Dr Perkins stated in OR, " That's one big a$$ cataract", a very unusual comment from Dr Perkins according too the OR staff. I only seen Perkins one time before surgery, the day before, and during surgery. I saw other M.D.'s at all other times that were very qualified. I also had a retina test done, about $100 my cost for both eyes), as they thought I had retina damage. Nope!
Expensive Eye drops (3), one for 1wk, 1 for 2wks and one for 4wks. About $188 cash and included in the total cost of $600/eye.
In May 09, I had CHF that left me with minus 960 in my left eye. I had a terrible time seeing and could not drive. I had minus 450 before CHF.
My left eye was done 2wks after. The same final results. The lens was a Acrysoft model SN650WF, UV protected, both eyes.
In pre-OP about 45minutes where I was put too sleep for 2min then was given
a shot in the eye in four places. I asked the Doc when he was going to give me my shots, "I already did". I didn't feel a thing. Four patients waiting at one time. My head was strapped too the table.
In OR for about 15mins total where it took Perkins about 7min on the right eye and 5mins on the left eye and he was done. They lay a cloth over your face so you can't see what there doing and will lay still. I could see very little out of the eye He was working on. A cut about 3/32 long to remove and install the new lens. Laser to remove the cataract and the difference in time, then flush the cat out. Fold the new lens then shove it in, then unfold, then Superglue the cut, then water test for leakage and were done. No stitch's.
In post-OP care for 10min max. Care instructions given and more eye drops and sunglasses. Another 10min sitting in the coffee room. Were done in about 1hr15min each eye.
Out of hundreds of patients that I saw, I seen two with extra problems and have no idea why or what surgery they had, so it could have been normal conditions for there procedure.
I would have the procedure done again in a heartbeat. My only suggestion would be too see several Doctors before choosing one.
I figured with a name like "Perkins", He couldn't be all that bad. I was spot on!!! Tractor related don't you know
Learning to drive again after 3mths, was a challenge. About 20min on country roads solved that double vision problem. I had to twist my head from extreme side too side too retrain my eyes to focus while driving.
Comments?
T_Bone
Comments?
T_Bone
