I was given (work exchange actually) a Ford YT16 yard tractor. It runs pretty well but the steering is pretty badly worn.
I have ordered some new bushings but that's only half the battle. The shafts are worn worse than the bushings are.
So here is a picture of the sector gear shaft, there is supposed to be a bushing at both ends, you can see the wear is pretty significant.
I plan to weld the low spots to build them up and then grind/sand back down to size. Any words of advice are appreciated as far as rod choice (I'm thinking 7018) and technique. Thanks
