battery pack
merlynr
I have this Lincoln grease gun that works great but the 7.2v battery packs are no good. It's about ten or more years old. My question is two fold. First off, are the six batteries in the pack(I have it open) NiCads? Second, the 12v battery packs looks the same on line and was wondering if that would work?
Well 999% to 1000 a 12v will not fit. Now do yourself a favor and find
your local "Batteries plus Bulbs" center. Many of them will rebuild
your battery with new lithium cells while you wait. What a staggering
differance! !
Hello merlynr,
Nicads are 1.2 volts each cell. The 12 volt pack will have ten cells. If you are handy, buy the pack and
use six cells to built yours up. Lithium cells have a different charger but they are the same size as
your nicads.
Guido.
Hello Steve@Advance,
You need a dedicated charger for the the type of battery. I have one that will do all three,
Guido.
When my Lincoln grease gun battery's died I soldered 20' of speaker wire on the terminals and put two clamps on the other end and use the tractor battery.
