Greetings,
I have a Ready Heater R115DT. It was a great heater until the rotor shattered. Now I am at 8 shattered rotors and have replaced the pump body and back plate also. Some of the rotors only lasted 1 or 2 gallons of fuel. Nobody and nothing I have discovered on the net has explained this. I have the manual and set the clearance properly. I have also used 1000 grit sandpaper to thin the rotor and get free turning. There is no evidence of bearing wear or shaft bending to the best of my measuring ability.
Does anyone know the answer or has anyone else experienced a similar problem? How long do pump rotors normally last?
Thanks!
Thanks!
