unusual (to me) diagonal cutter
Will try to load pics. I have an unusual diagonal cutter with sort of double jointed arms. Apparently the design is to get a long reach from handles to the cutter jaws, without having the extremely wide opening of the handles like some cheap products have. Does this design have a specific use? Seems it would be pretty costly for just casual home repair shop.
Dennis M. in W. Tenn.[/img]
Clearance side to side, and distance from potential contact with moving, or electrified or sensitive components takes a tool like this. It might have rare usefulness, but high
value when used. Snipping the off color green wire with the light green trace deep in a timer to defuse a small nuclear device seems an appropriate use. Jim
What if it was made by IHC and they all were the same color !
Green with numbers on them that easily wiped off. That was what my Scout had.
With compound pivots it should have much more cutting force than a single pivot cutter of the same length.
Kind of looks like an old pair of what we call "musky" pliers.
One model of [b:4bda81e63e]Greys - Prowla Angler pliers[/b:4bda81e63e] are about as close to the one you show that I can think of.
I doubt you would find a specific reason for those. I have several pair of those but they are modern snap on and matco. 2 pair of cutters, a 1 pair of needle nose. They are real handy for the exact reason you mentioned, cram them in a tight engine bay or under a dash where space is real limited and you will appreciate them
