Mule Meat
A guy gave me a Husqvarna 365 chainsaw with a new set of crank seals and gasket kit. It runs but is very weak with low compression. I think I will get a 50mm cylinder kit that fits a 372 and use it as a big bore kit.
Next are two Edgers. One a Mclane 803 with a 3 1/2 HP Briggs from 1983 and the other a Craftsman 536 with a 3 1/2 Tecumseh. It does not have the correct oil cap. So I will get the correct one for it. I have a feeling that with the new stick edgers that run with weed whacker engines will take over and these old wheeled models will fade away. So I grabbed them to have something to tinker with.
I had them both running for a few seconds from gas poured into the carb. I will clean them up later and wait for some museum to call..
