New Holland 1431 snagging hay
Anonymous-0
I have a 1431 that is snagging hay with 14 degree blades bad the 2 heads on each outsides cut great the 9 heads in the middle cut bad... any advice
Are your lifters facing the right way? after probably four seasons with my 411 I noticed last summer that two of the discs had apparently been swapped, probably at the dealer just before I bought it. The knives were turning in the right direction but the lifters weren't. Also do you have it turning fast enough? I would expect that it is a 1000 RPM machine.
Yes the lifters are in the right direction....I even have taken the lifters off. Maybe the disc are turning the wrong direction I just bought the machine in October of last year it cut good in thick dry hay ..but not thin or really good hay
Thanks for you advice
I would assume the Disc are turning in the right direction but I will check that out... the blades are on correctly
