my 1956 Allis Chambers WD-45
Hi I have a problem with starting it This has been happening about every time i go to start it. Can someone help me out.
Thanks
Larry Hainlen
If the starter spins the engine but it does not start, it is either ignition or fuel/air
If the starter does not spin the engine, the Battery can be poor, Connections corroded, or the starter switch can go bad, or the starter brushes or bushings can be worn. We need details to finess an answer worth reading. Jim
You know it cost the same wither you use one word here or 100 so with as little as you have said no one can help you since you only say it does not start but does it even have a battery is it good does the starter turn the engine over etc etc. NONE of us can read minds so at this point no one can help you help your self
(quoted from post at 19:49:48 09/07/11) Hi I have a problem with starting it This has been happening about every time i go to start it. Can someone help me out. I`am sory that is what hnappens when you get in a hurry.
It has a new battery new wiring new coil new points rebuilt starter, rebuilt generator and it turns over great but won`t fire.
Thanks
Larry Hainlen
