Waldon 5000 Hyd Pump
Pete OH
New User
I am working on a Waldon 5000 loader from 1979,I am missing the hyd pump which is actually two vicker mounted piggy back.The factory will not give me the model numbers and want $3000.00 for a new one,can anyone get the number off their pumps for me?Thanks
Why not swap the vickers pumps with a commercial stackable pump.(much cheaper and just as good)
That is what i did on my waldon 500.The drivemotor on my waldon is the same brand.
As you know finding the actual pump numbers would be the easiest way to get the right pumps. If you can't find the right numbers, if you can get just the specs for each pump you could still find another brand to take the place of the origionals. Like Bison's post says the Commercial pumps should work perfectly and are typically available at a reasonable price.
That said I just did a Google search for Waldon 5000 and got a few hits including one from an old YT mag post. Click on the link below for a link to that discussion. One of the posts had the name of a place listed, not Waldon, that might be able to help you figure out what you need. Good luck.
Past discussion
Thanks for all the help guys but if I could get the model numbers of what pump you used it would take the guess work out.From what I gathered the drive pump is 34 gal min,and the lift is 17 gal min both at 2000 psi.What do you think?
