TimWafer
I am going to look at some different wheels for my Farmall 656 tonight. I tried to measure the axle & hub diameters last night in the dark but all I had was a tape measure & my phone. Not sure how accurate I was. The axle looked to be 2.75” and the 9-bolt hub diameter was about 8.75”. Attached is a picture I took with the phone. Do these dimensions sound correct? Do most 9-bolt hubs have that size center hole?
Thanks
Tim
9 bolt 8.75 inch pilot hole is a standard wheel size. You can put just about any 9 bolt rim on your hub. You just need to make sure the off set is usable on your tractor.
