Wayne in MN
This car is in my heated workshop where I keep my snow moving tractor, so I am close to being "on topic"!
My daughter bought a 2000 Buick Regal for my "almost 16" granddaughter. Nice driving machine.
Problem: when shutting down after moving the car, the key cylinder doesn't always rotate to the position where you can remove the key. With a floor shifter, I suspect a linkage adjustment is needed somewhere to allow the key to be removed.
I also found out that by not being able to remove the key, the battery will run down!
Any GM experts out there with a suggestion for fixing this problem b/4 my granddaughter is leagal to drive? (about a month)
Thank you.
Thank you.
