Tuthill 12v fuel pump?
paul
Are the Fillrite 12v fuel pumps all right? This would be perhaps the lower priced, 15 gal/ minute version. Don't want to buysomething that burns out in a year, but I don't need all that much pumping as I only go through 1500 gallons a year, most gravity flows out of the tank, just have to pump to the combine tank.
Good enough or junk?
--->Paul
I still use a hand pump,but I do see a lot of those electric ones.So they must be good.Any pump is better than a 5 gallon can....
We pumped hundreds of thousands of gallons with Fill Rites on the harvest and they didn't give a hint of trouble. Jim
(quoted from post at 21:02:27 03/12/12) Are the Fillrite 12v fuel pumps all right? This would be perhaps the lower priced, 15 gal/ minute version. Don't want to buysomething that burns out in a year, but I don't need all that much pumping as I only go through 1500 gallons a year, most gravity flows out of the tank, just have to pump to the combine tank.
--->Paul
They are about the best you can buy for the money, I have two that I bought in 1975 and they are still pumping have replaced the vanes in both and a check valve they've pumped 1000's and 1000's of gals of fuel gas or diesel.
GB in MN
