Anonymous-0
I have new Tisco piston sleeve set (Not yet installed) and am not sure about the correct piston clearance. The manual says .0025 with the feeler gauge at the skirt?
1) Being the skirt is cam ground (.025 out of round)is the .0025 clearance measured at the tight area of the skirt?
2) What should the clearance be at the crown area where the rings are installed, I slipped a .009 feeler in at the crown with no problem, is this excessive?
I guess that after checking the piston to sleeve fit by hand the clearance seems excessive to me, the only area that seems to fit well is one area at the skirt
