Posted yesterday of problems with fuel vaporizing in sediment bowl, causing vapor lock on '49 JD "B". We were using it in manute loader service, and not pushing it hard. You could look into the top of the bowl, (from below) and see the bubble of vapor. Last time this happened, back when we had the hot spell in March, son was plowinging with 2 16" plow. Could actually see a couple of streams of bubbles rising off the bottom/side of the glass bowl. So we're sure it's happening in the sediment bowl assembly. Today the temperatures are qbout 40 degrees lower than yesterday, tractor was running fine. Neither time was water temperature excessive according to the temperature guage. (180 degrees or so.)
