senior moment at work
SDE
I used a torx bit in a screw driver type handle to remove two screws from a drill that uses different sizes of Spade bits. After searching for the correct insert, I needed to find the drill again. After looking for it a few minutes, I saw that the screw driver was setting on the work bench. If that is there, then what is in my hand? I usually set the drill down, but not this time. Found it in my hand.
When I retire I hope to move at a pace that is compatible with my brainwaves.
I had a neighbor that had such poor eyesight that she lost her glasses while looking through them. You have no worries. Jim
Have a long list, but I did just that; going out to eat, looked for the keys, looked, the whole family looked, and looked, I had them in my right hand.
How come whenever you're looking for something, you alwaysfind it in the last place you look? Why not look there first?
The other day I was looking all over for my cel phone. Then realized I had it next to my ear and was talking to a friend with it.
(quoted from post at 20:56:58 09/11/13) I used a torx bit in a screw driver type handle to remove two screws from a drill that uses different sizes of Spade bits. After searching for the correct insert, I needed to find the drill again. After looking for it a few minutes, I saw that the screw driver was setting on the work bench. If that is there, then what is in my hand? I usually set the drill down, but not this time. Found it in my hand.
Sounds like me lately :roll:
Had you not found it in the last place you would still be looking.
I have an inventory logging problem. Can't remember what I have and if I do, lots of times I don't know where it is.
So I started thinking about where I would start looking for a particular item before I put it somewhere. That's where I put it.
Works for me.
But I too have as you and the other guys. The cell phone however is way out there.
Mark
