Texasmark1
Need your help again. I added the spring fingers to my chisel plow and I ran out of fingers...normal attrition I guess. I have no idea as to what the assembly was part of initially, nor any part numbers. "Got any ID?".
Thanks,
Mark
Do you just need some teeth? N135002 Spring ADD 8.92 USD . I think this is the correct style as there were 2 different styles of frames. One style the teeth were bolted rigidly and the other the teeth swung or pivoted on the bars.
You got the right one. Spring fingers, I call them, bolt on to the
front of the channel, not the top and the fingers are all that move
against the spring obviously. If I read you correctly the spring
finger, Item 4, is JD PN N135002 at $9 per pop? Yes?
Mark
Ok sir. I just realized I put this in the wrong category...Tractor Talk,
but it got the desired result and looks like the folks overlooked my
error.
Thanks again for your help.
Mark
(quoted from post at 09:23:48 10/30/13) Ok sir. I just realized I put this in the wrong category...Tractor Talk,
error.
Mark
IMHO the forum title doesn't mean a lot. After all it takes a tractor to pull the implement.
Yesssss. Nice thing about this forum and the forum cops is that
they are accommodating for us senior citizens.
Mark
They will be in tomorrow at the dealer. Good old green. Coming
through again. $8.92 just like you said. Just wonder how my little
Branson will do on parts 40-50 years down the road. Course I
won't have to worry about it. I'll be pushing up dasies long before
that.
Mark
