550Doug
- Location
- Southern Ontario
The American Bosch PSB pump on my Hercules 298D motor has 6 injector lines from the pump head to the 6 injectors, and one is leaking at the pump head because of a bad ferrule. I have a good injector line from a Hercules 339D motor but it is considerably longer than the leaking one. Is it possible to cut off about 8 inches of the good line and replace the 8 inches of the bad line by doing a splice of the steel lines? Will the pressures inside the line cause failure at the join? Has anyone tried something similar?
Thanks in advance
Thanks in advance
