Need Marvel Schebler help for 275 cub inch engine
I"ve used the TSX series before and like them because they"re simple and work.
I need one with a 1-5/16" max throat and that can feed a 1400 rpm max, 4" x 5.5"" stroke 4 cyl engine.
I used a TSX-813 before.
Any other suggestions? Is there a master spec manual that shows engine size, throat, and bolt spacing?
zenith carb replacement may be your best bet . call the people on this site under parts they know the sizes
What brand of engine is it. Know that will help us help you. Places like nnalert has a good many M/S/ carbs that they have rebuilt but again they will be likely to ask you the same thing I did
Cletrac engine. The Cletrac crawlers use Hercules engines in many of them. So maybe you need to try Zimmermans they have many parts on hand for the old cletracs. I have an old HG42 with a Oliver 60 engine in it
Looking for a manual that shows throat diameter, stud spacing, inlet diam, cubic inch use.
Any body ever seen one?
Thanks
