(quoted from post at 12:15:28 03/03/14) Never heard of a spark plug blowing out of a Chevrolet...
o just rods lmao hey btw 4.3 need i say more one of the worst engines ever(quoted from post at 20:15:28 03/03/14) Never heard of a spark plug blowing out of a Chevrolet...
t is a stretch to claim no defect, as Ford DID come up with a fix in the replacement & later factory heads by increasing the thread depth to get 5 or 6 threads instead of 3. Note the dates that mark the problem heads 'before' and no problem heads, 'after' the specific date.(quoted from post at 12:49:54 03/04/14) If everyone is having the same maintenance problem its a bad design = design defect.
Changing spark plugs isn't difficult and shouldn't be -- except in a ford.
By the way if you follow the Ford procedure their is still a very high probability that you'll end up with the stripped plug blow out problem. And ford recommends a head replacement - and a number of dealers recommend a new motor as the cost of the head replacement is high
The problem is that they didn't leave sufficient metal / or use a stronger alloy in the heads where the spark plug threads are. When you remove the plug you end up tearing out some of the surrounding metal. The new plug goes in without sufficient good threads to hold it in and it blows out.
Again design defect
just because you were the exception and had good luck doesn't diminish the problem
If it was simply some one over tightening the plug until it gets easy then I'd agree with you.
But from everything I've heard it's more than likely the removal that's causing the problem.
(quoted from post at 17:16:38 03/03/14) Seems like it is always the back 2 on the passenger side when I see this happen. There are several ways to do it, but I have found a heli-coil is best.
(quoted from post at 03:11:29 03/05/14) I have a 2002 Ford E-350 5.4.Bought it with 125,000 miles.At 140,000 it blew a plug. I changed all the plugs at that time.And was lucky it didn"t need a heli-coil. This past January with 215,000 miles, I started it up to warm up. Maybe ten min. of idling. I didn"t get 2 feet out of the driveway and it happened again.Different cylinder this time.Lucked out again and and a new plug went in and held.(for now).After reading this thread I"m starting to get freaked out. So I called the dealer to see about changing all the plugs.! new coil pack $78.00,(2500 miles driving around with the coilpak broken and just hanging on the plug)$5.26 for each new plug.5 hours labor @$430.00 (yes it is a van,very tough to work on) They will warranty 12 months or 12,000 miles. I hate to drop that kind of money.But how lucky can the third time be?
