rustyacres sd
Had the finish mower on the mf135 and parked in the shed. Went to mow the other day. No go. Just got a click sound. Put on battery charger. No luck. New battery. Same crap. Ok Selenoid on starter. Replaced starter. (PIA on a 135 because you need to remove carb.) No luck. Got 12V down to the starter and fuel shutoff solenoid. Talked to one mechanic. Said short, Massey mechanic said to replace battery cable ends. Had a ground cable on the wall also, so new ground and new positive cable end. Fired first crack. 500.00 and it could have been saved with a 2.49 battery cable end. My LUCK.
Started to mow the edge of the property, and got rained out. not enough to measure in the rain gauge, but it did settle the dust.
