Anonymous-0
I have a 1995 Honda 5518 (gas engine) tractor W/midmounted mower that about 10 years ago broke down due to low compression in one cylinder. Initially when I got it, it ran ok, a short time layter I changed it over to a Hydrualic frontloader which required me to remove the mower part, after that it ran most of the time with the engine underloaded ( the frontloader uses a lot less power then the mower ). That I think eventualy unseated the rings in one of the cylinders if so I think the easiest fix is to remove the head and look for glazing in the bad cylinder. If that is the problem what would then be involed to fix it; get a new piston and rings, boar out the bad cylinder or hopefully just deglaze the cylinder? thankyou.
