Michael Price
After watching this tractor rot away most of my life I was finaly able to buy it. Its going to need a new engine and a lot more but its mine now.
white 2 105
white 2 105
(quoted from post at 05:42:56 09/09/14)but it shifted not worth a fart...always grinding gears.
have 3 off them 1855's,(one of them is awaiting a rebuild) i have the coasting problem as well but my land is fairly flat, i also use mainly 4th gear, none of them shift easy. they are hard to get in gear from a standstill or from forward to reverse, high to low is even worse. As such i find them useless for loader work.(quoted from post at 05:38:14 09/09/14)(quoted from post at 05:42:56 09/09/14)but it shifted not worth a fart...always grinding gears.
I almost never ground gears in my 105,[b:2d6bbc1234] or the 1855[/b:2d6bbc1234], they shifted extremely easy. The thing I don't miss is the low[b:2d6bbc1234] coasting down hills[/b:2d6bbc1234]. I don't have many hills, but a few little ones, starting a bale with the round baler I used 4 low. Going down hill that didn't work very well, 4 direct was too fast when the hay was thick to get it started, so I'd just downshift of course so I could use direct and not "fly" too fast starting a bale, or rough patches downhill, and not have to ride the brakes. Other than that, 4 was the only gear I needed to use baling. But that's about the only operating complaint I had.
