8n ford hydraulic lift arms
Sclem
What is wrong when control lever has to be turned farther than lever in normal position allows. I took back bolt out of control lever so as to rotate shaft farther counterwise to get lift arms to move upward. Now it will not lift arms. Where should I start for repairing the lift arms? Thank you for any information.
You'd probably get more precise answers on the 9N/2N/8N forum
here on YT. If you post it there, also mention if you are in draft
mode or position control mode and if it does the same in both.
