Got 'Em Together
Goose
Got 'em put together. The M Farmall and JD #5 mower. While I was at it, I put all new guards and sickle sections on the sickle bar.
Works fine, but I am not a fan of raising and lowering the sickle bar with Farmall's rod to pull and push to raise and lower the sickle bar. You can't just raise or lower the bar an inch or two, it's either up or down.
My H with the loader has a double valve mounted by the right headlight and plumbed into the belly pump, with one lever for the lift cylinders and one for the bucket. I'll do the same on the M. All it will take will be a single valve and a few hoses. You run the pressure line off the pump and put a T fitting under the fill cap for the return line.
I had this same setup on an H once. I don't know if it's the motion of the mower or what, but it seems the mower always stays to the right.
I would still put one of the split collars with the two bolts and clamp that baby. You said "never" and you can bet you caboose it will. I will have to post pictures when I get my Gravely five foot bar all together in the next week or so. I TOTALLY rebuilt it . Knife and sections, Points,guards, or fingers as what everyone calls them, and wear plates and clips. New bolts too! Don't sickle bar mowers mow SLICK when everything is correct and sharp!!!!
The #5 John Deere had an optional hitch for the Farmalls. Basically it is a flat bar that bolts directly to the Farmalls Horseshoe drawbar.
