t will tell you when to change it. My truck usually goes about 7000 miles between changes. 3000 mile oil changes went out with 8 track tape players.(quoted from post at 08:57:31 06/03/15) What is the proper time to Change oil In a auto or pickup with a oil life gauge? Do you go by mileage or the percentage of life left of the oil by the gauge. Thanks.
(quoted from post at 22:11:27 06/03/15)
Consider what is really important . Nowadays it's low sulphur fuel,unleaded fuel and clean combustion due to computer controlled fuel injection. Anybody promoting 3000mile oil changes is still stuck in the 1970's.
(quoted from post at 12:39:32 06/03/15) Far as I'm concerned the automakers have outsmarted themselves. Cadillac/GM has learned what 6000-8000 mile oil changes with their 3.6 engine. Every new version of it claims they've fixed "the" problem. Variable valve timing and hydraulic chain tensioners need clean oil to operate - maybe some day they'll get the tolerances to the point they can work with 6000 - 80000 mile oil changes but right now they can't. If you don't have either then then run the oil longer. A 2000 4.6 2V engine will go 8000 miles easy, but a 2010 4.6 3V with cam phasers needs clean oil and trying to save a few dollars will result in very expensive repairs. Every auto maker out there is having trouble with their "advanced" variable valve systems and/or sludge and all of them are blaming the owners for neglecting their engines even when they follow the manufacturer specs on changing the oil.
(quoted from post at 13:09:32 06/03/15)(quoted from post at 22:11:27 06/03/15)
Because of damage to the emission system (Catalytic Converter) the industry has been phasing out zinc and phosphorus levels = less lubricating additives that get used up sooner...
GM admits there oil life monitors are wrong when it bit them in the arse when cars were failing under warranty... It was a lubrication problem caused by recommended extended oil changes going by the oil life monitor... For the last year are so GM would reprogram the monitor to a more realistic interval "FREE"...
Folks can believe what they want to believe it does no damage by changing your oil in the 3 to 5K range depending on how you drive.. Roll the dice when damage does accrue its not reversible...
With Variable Valve Timing and GDI (Gas Direct Injection) extend those oil changes you are not gonna like it...
(quoted from post at 15:05:37 06/03/15) You summed that up perfectly, I just recently retired from a GM dealer and those long oil changes really screwed up a lot of equipment.
(quoted from post at 18:48:29 06/03/15) I don't trust the percentage of life left of the oil by the gauge. I have 3 GM vehicles. At 3k it's time to change oil and none have used a drop of oil. At 4k all 3 vehicles are down a half qt and the oil is very dirty. At 5k oil looks like mud and oil is down 1.5 qts. Some only hold 3.5 qts. All oils are changed at GM dealer too. So much for the percentage of life left of the oil by the gauge, be smart, check dipstick watch color of oil.
(quoted from post at 19:57:24 06/03/15) I let my dealer service my cars, especially when they were still under warranty. It
seemed like every oil change they had something to repair. I'm sure they didn't use
mobil 1. I'm also convinced they the non synthetic oils break down faster, then engines
begin using the oil. Oil changes are cheap compared to a new engine.
