Oil pressure gauge broken glass
Search "auto instrument repair" or "auto gauge restoration".
I can't recommend one cause I've never actually had any work done, but I have see some before and after work.
Amazing what they can do!
A simple glass replacement should be no problem for someone that knows the tricks of the trade.
the centre ring that the glass is in should be a press fit
but it may be threaded
as those gauges were assembled from the bottom up and the last piece installed is the glass
due to its age and application I sure it will be hard to replace and not knowing if it's pressed in or
not makes chancing more damage a big worry
do you have any other gauge similar to it you can try prying apart
only other suggestion I have is to cut the metal ring around the edge to remove the glass and put back
together with JB weld and sand smooth when dry and repaint with time and work you wouldn't even know it
was done
Got the ring out. No screws. It was just corroded. Double ring assembly held the glass in place.
Thanks for the help everyone!
