JD elevator
4520BW
I have run out of shed space and now my elevator has to set out. It prob 50 years old and never has been out in the weather. I oiled it down with used motor but was thinking I could cover it with some tin zip screwed to top on trough? Any one do this or have a better idea? Thanks
For my hay elevator, I rigged up a bracket on the pole barn post and use a chain fall to lift the elevator up near the ceiling for winter storage.
Is that a double flight elevator? We had a double flight that was galvanized so it sat outside in the weather year around.
Is there anyone who still has a JD tubular grain elevator? My uncle had two of those; they were real heavy and clumsy to move around, but they would move a lot of grain if the power unit was adequate.
This is an old ear corn type on wheels. I keep my hay elevator like your talking bout in my rafters out of the way but your idea would be easier then wrestling it into the rafter!
My American Standard double chain elevator sat out for 20 years. I oiled it well with used motor oil,removed the motor & V-belt. Sold it to a neighbor, still sits out, never had any problems with rust. Probably 95% of the elevators around here sit out all year.
Just make sure there is no dirt in bottom to collect and hold water and it can drain out any water that does get in there from rain-snow.
I stored my elevator outside for years. I took some metal siding. I start at the bottom. I cover the trough with the first sheet. I have a small board cut to hold the sheet up in a bowed out shape. You put the board in the middle of the elevator to hold the center of the steel up. I then just wrap tarp straps around the steel to hold it down on each end. You just work your way up the elevator. You end up with the main part covered with a Quonset hut shaped cover over it.
I"ve never seen a hay/grain elevator in a shed, or covered in any way. Just make sure the bottom is cleaned out.
I have a winch on top of hay bale elevator. A few cranks of the handle and it's out of the way. Bottom uses a come-along, and it's up in the eaves and out of the way. almost self storing!
