small tractor pto shaft cover removal
MGR
New User
can anyone shed light on how to remove a neapco pro safety cover that has 4 white tabs on each end? they look like they should push in but i can't get them too
They don't push in, there should be a screw or a tab you push in, then turn the collar a few degrees, and slip it down over the long sleeve. Then the white piece with the 4 tabs has a split in it and you squish it to get it off the long sleeve, then spread it to remove it.
