A few pics from today
larry@stinescorner
I passed by this tractor loaded on a trailer todsy
and spotted an old planter
A good friend of mine gave me this three pt harrow,I just have to figure out how to move it now
I believe the machine in photos 3,4 & 5 is a mechanical transplanter. Looks kind of primitive, but I'll bet it speeded up the operation and made it easier too!
If you can lay the levers down flat, just turn it upside down. That is the first spring tooth that I have seen with a 3 point.
I think it's an 'H'. Since an 'M' is a little longer than an 'H', the steering rod is shorter and more steeply slanted on an "H".
If I'm wrong, I'm sure I will be connected.
Stan
You're right about the slant but I think the H and M are about the same length since they both could use the same loader and cultivators and such. My impression is that the M engine is a little taller and that sets the steering support bracket up higher on the front end where the steering shaft goes above the engine thus making the shaft run closer to horizontal. I have had several Hs but no Ms so I may be all wrong about this.
Zach
I have a drag just like that. Well, maybe a little more beat up. Any idea who made them? I was leaning twards home made, but now I see there's more than just mine.
The tractor is an H Farmall. The trailer is loaded tail heavy. The yellow implement is a mortar mixer, built with its own small engine in the somewhat rectangular compartment. So it is not a tractor implement.
Paul in MN
Yes it is a transplanter there was a wooden barrel mounted cross ways in front of the wheels and it was set up with a trip as wheel turned the wheels would cause it to trip and release some water in the planting furrow and you would set your transplant in the water and the water draw the root ball of the plant into the ground.
You're correct.
I have two H's and an M. The M's engine is about an inch and a half taller than an H, going by the "neck" at the top of the governor. The governors interchange, except the top neck and linkage are taller and need to be mated to whichever tractor it's on.
Also, IH built the M's and H's on the same wheelbase intentionally so mounted implements would interchange.
You don't really realize the difference in size between the two until you get off of and H and onto an M, or vice versa.
My grandfather had a Ferguson, neighbors had a Dearborn. Looked the same but weren't quite exactly the same. I know Pittsburgh Forgings and Farm Tools Inc. made stuff like that for said companies to brand back in the late 40s, early 50s, not sure who exactly built what for whom though.
If my memory serves me, I recall a trivia question that tripped me up. The H is physically longer than the M. How it is measured I can not say so I trust an IH man will confirm or discount this tid bit.
Hey Larry, check that harrow over for a case eagle on it. It could be a case made for the eagle hitch
tractors. It looks different from the ones I've seen, but similar.
That hitch to me says Ferguson and some Massey Harris implements were same as Ferguson except for paint. Cannot tell if color is paint or rust. If Ferguson on part that holds top ling should on lrft side have a tag or rivits where one was. The Ferguson rotary hoe hitch was made exactly like that hitch. Moving just take apart. The rods lifting the back should be just a pin with cotter to hold to lift frame with 3 bolts at bottom to remove it. then to take apart each section should be to 3/8" bolts holding 2 sections together. Usually rusted and beat, may need to cut them out.
