Good source for a 4 bolt implement rim for my KBA Disc?
Will Herring
I think the old rim is beyond saving (rusted through about 4 inches around where the valve stem *should* be). Any good/reputable places to order replacements from? I'll take a decent used one or a brand new rim, since I'm already going to be buying two new tires at this point. Need to measure the tire size still, forgot to do it before it got dark.
(also hi all, long time no see)
(quoted from post at 19:24:29 04/17/16) I think the old rim is beyond saving (rusted through about 4 inches around where the valve stem *should* be). Any good/reputable places to order replacements from? I'll take a decent used one or a brand new rim, since I'm already going to be buying two new tires at this point. Need to measure the tire size still, forgot to do it before it got dark.
Pretty common rims, I have a bunch of 14" laying here as it is harder to find tires for them. If I were you I would find a set of 15" rims.
JD dealer can get one if you can't find used one.
JD455 Wheel - 15" WHL RIM FOR RUBBER TIRE ADD 109.86 USD
JD1754 Wheel - 14" DISK WHL RIM ADD 112.22 USD
My local coop keeps them or they can order them. There are several places online where they can be bought. Do a google search and you should get a lot of options. Some places offer free shipping if the order is over a certain amount.
Don't remember for sure but I'm thinking those old F100(?) JD field cultivators had 4 bolt wheels and were probably 15". Brother has one parked in field close by. Will have to take a look. Also, some JD models of older plows have 4 bolt 15" wheels.
(quoted from post at 11:34:58 04/18/16) My JD 210 disc had 4 bolt wheels, pretty sure they were 15 inch. They"re not uncommon.
Someone must have changed hubs/wheels on your 210 as 4 bolt hubs/wheels aren't listed in 210 parts catalog(# 1391).
