MattCatlin
Hi guys, I have a 24 volt 4010 that so long as I run it for a hour or so every couple weeks will keep the batteries charged. Tractor wouldn't turn over so I disconnected all the cables and charged each battery with jumper cables from my truck for a few minutes. The short lead that connects the two batteries together is sparking at the positive hub where the ground is. Melted the terminal some. Everything is hooked up right the cable lengths don't allow it to be hooked up wrong. Tractor starts and runs after the spark. What's up?
Thank you
Thank you
