Recently began having troubles with the hydraulics on my JD 2640, first chattering when running the FE loader and now loss of steering when warmed up Mechanic is looking for problem, says likely internal hydraulic pump. Here's the question: a year ago when I put the loader on the tractor, I changed the hydraulic oil with a "meets JD specs" oil from Tractor Supply, Naviguard if I recall. Now I am wondering if that caused the pump failure. When I was at the JD dealer, I noticed that he sells the same stuff as I had bought considerably cheaper than the JD Hytrans which he also carries. When I asked him what he thought about the cheaper oil,his reply "I wouldn't use that stuff in your tractor." Putting aside why he sells it at all, what do you think. Is there really a difference if the ratings are the same which according to the bucket label they are. Did that do my pump in?
