im just in for another part, im working on a late 60's ford 2000 3 cylinder gas, it ran ok, then slowly shut down, owner dragged it into the barn, now we have cleaned out the fuel system from carb to the tank, have plenty of gas thru the carb, new points plugs, condenser ect everything appears to be working, we have spark, but this thing takes a lot of choke and a lot of cranking to start, if it actually does start, it idles fine, but when the throttle is pulled, it farts and craps out and wont run up in rpm, im about out of ideas, and i was brung in the middle of this project it seems to have decent vacuum, so that rules out mechanical damage at least enough that it should run right? any ideas?
