3 ton truck brakes
oj
My 3 ton, a 1976 IH 1800 loadstar has a bit of an issue with a brake sticking on, happens to be the left (drivers side) front brake. I usually just crack the brake line from the master cylinder and the brake let's go. So I suspect I have a master cylinder issue, or could there be another cause? Truck has a vacuum booster (under the cab).
Yup. The hose has separated and collapsed internally. It will let pressure through to apply brakes but won't let it back to release pressure. Have Napa make you a line.
One wheel sticking and it releases when you open the bleeder? it has to be the rubber hose.
If bleeding the line releases it, the restriction and repair issue must be between the point of your bleeding, and the booster, or in the booster. It probably has a Hydrovac booster. If there is a "T" in the lines going to the front brakes, and bleeding the other side, or a front wheel cylinder bleeder on either side releases it, it might have a broken return spring on the affected wheel. Jim
So where are you cracking the line?
At the master cylinder on the firewall? If there is pressure building there, it would affect all the brakes, not just one... That can be either a sticking master cylinder, caused by rust and corrosion holding the cylinder from returning, or (worst case) oil has been put in the system and the rubber cups are swollen, or the linkage is out of adjustment not letting the cylinder fully return.
If you are cracking the line down at the left front wheel, then yes you have a collapsed rubber brake hose.
I must be living under a rock! NAPA can now make a brake hose just as they would a hydraulic hose--wow! That seems like it would have "liability" with a capital "L". They must have a way to pressure check the completed assembly. I would want to "A" know and trust the parts man making it for me or "B" be able to watch the entire process with my own eyes before I would consider that for any vehicle I'm working on.
Cracking the line at the master cylinder, but only appear to have the one brake sticking on, deduced by high tech method of touching each drum to check for heat, left front always hot, the other 3 less so
Hi used red. I bet there are no more liability issues than buying a junk hose from the land of almost right. I got a brand new manufactured steering hose for my GM truck in town . It lasted 3 weeks and blew out. I kinda mentioned it to the parts guy, he said that was the 6th one they sold that did it! so even a factory produced one might fail quick. I think after that the NAPA guy might do a better job!.
(quoted from post at 21:24:04 08/06/16) yes agree, i have never heard of making brake hoses..... nor a power steering hose.
They are not grown, they are all made. Mostly in China if that makes you feel better.
I had a similar issue in the past. What I found was that a steel clamp around the hose had grown enough rust between the clamp and the hose that it pinched the hose tight and would not let the disc brake pads retract. The pressure applying the brakes was enough to overcome the pinch. This would cause the pads to drag and overheat and warp the rotor and smoke the lining. The same thing could work with drum brakes as the shoe return springs would not be strong enough to retract the shoes with a pinched hose.
