notjustair
I have a little 8N Ford I use around the barnyard to move trailers. I have a piece of channel that goes from the 11 hole three point drawbar to one of the lift arms. A muffler clamp holds it down keeping the ball from forcing the drawbar to rotate. It works nice to move trailers for mowing and things.
I bought a round bale hauler with a ball hitch. It's not the kind you push on from the back, you put them in saddles on either side. I hooked it to the 886 and used the same method to keep the ball from rotating. I can pull it to the field and set down the three point, unhooking the trailer. I can load the trailer and then pick it back up with the three point and pull it home. I don't have to jack it up or have two tractors.
My problem is that I can't get any kind of stiffener to hold up with that much weight on a Cat 2 hitch. Everything I have tried bends and allows the 11 hole bar and ball to rotate.
Obviously I want it fairly fast to take off as it's a chore tractor and gets its share of other uses. Has anyone else used a cat 2 three point drawbar to pull a ball implement rather than the conventional drawbar? How did you keep it from rotating?
