(quoted from post at 09:30:05 10/11/16) I have a 54" with the Kohler engine and the only complaint that I have is that the machine is too fast for the blades. It does not create enough rpms for me. It will cut decent enough if you don't mind going slow.
(quoted from post at 10:23:36 10/11/16)(quoted from post at 09:30:05 10/11/16) I have a 54" with the Kohler engine and the only complaint that I have is that the machine is too fast for the blades. It does not create enough rpms for me. It will cut decent enough if you don't mind going slow.
Just curious what you set your blade hight at? I was noticing that on mine when the blade is set to 3.5 if I drop it down 3 it's a little better if I go down to 2.5 it cuts ok at higher speeds. Only does it in the taller grass.
