Probably as good as any.(quoted from post at 18:27:39 11/27/16) I'm looking to buy a hand held router. Looking at the Porter Cable. Is this a good one or should I consider others?
I've never owned one before. It says this one has a fixed base. Is this a good thing or bad? Any input would be greatly appreciated.
Router
(quoted from post at 19:27:39 11/27/16) I'm looking to buy a hand held router. Looking at the Porter Cable. Is this a good one or should I consider others?
Router
(quoted from post at 17:49:08 11/27/16) You might want to consider a "plunge cut router" instead of a "fixed base" router. It will depend on what you want to do with it. The plunge cut can be used both ways by just locking the base in place to use it as a "fixed base" router. You might want to actually try/use each type to be sure which type will be best for your uses.
