west illini
New User
I have an oil leak under the dash of the 4450, and suspect the steering pump. I did have a pressure hose blow a yr ago, tried to clean it behind the dash with contact cleaner.
Is oily damp all under the dash, continues under the cab, collecting dirt, with an oil trail down the side of the trans.
I wiped the pump off with a paper towel, and ran it, moving the steering wheel, but am not able to see any seepage at the seam of the pump
I am also able to turn the steering wheel 20-40 deg before the front wheel turn. It has about 11,000 hrs.
Is there another way to check it, without totally dismantling the steering column?
thank you
thank you
