imply because his tractor does not have the very different solenoid (extra contact) that Deere had, which by the way is the same way GM cars & trucks did it for more than a decade.(quoted from post at 17:55:36 12/31/16) I don't get it?? A diode as has been stated is an electric check valve. Why do you need one in line to give your 6 volt coil 12 Volt?? Deere used this system for years with no diode. They used a 6 volt coil with a resistor in line to get 6 volt at the coil. Then when starting a wire comes directly from the starter to the coil to give it 12 volts when starting. Your diode system makes no sense to me.
(quoted from post at 14:34:06 12/31/16) I have no way to confirm, but I think applying 12v to a 6v coil will make a hotter spark when starting. How simple is it to add a diode?
(quoted from post at 20:52:43 12/31/16) That how cars were wired, but Jubilee has a
starter button that energizes solenoid by
providing ground. No ignition switch like
cars use. No terminal on solenoid to
By pass ballast. 'Other tractors mat use a
manual starter button, No solenoid, then
only option is diode if you convert from 6v
to 12v.
(quoted from post at 04:56:19 01/01/17) Back in the late 50's I put a resistor bypass starting system on Dad's Moline GB propane tractor. They originally came with a 12V coil that did not need a ballast resistor. The tractor was a poor cold weather starter and was hard on points, usually had to replace them twice per year.
We had a wrecked 55 Chevy with ballast resistor and matched coil that was a great cold weather starting car. I wondered if I could improve the tractors cold weather starting by fitting it with the Chevys resistor bypass ignition system. I fitted the Chevy coil and ballast resistor to the tractor , but the Moline did not have the 4th solenoid terminal to bypass the ballast resistor while cranking. I knew I could not connect a bypass wire directly to the starter stud as it would back feed power from the coil into the starter which would short out the ignition. I got around that by using the 55 Chevys horn relay to feed 12V to the ignition coil to bypass the ballast resistor and feed 12V to the coil for better spark when cranking. When not cranking, the relay opened the connection to the coil so I would not back feed to the starter.
The system cobbled together out of junked Chevy parts worked well. The tractor would now start in much colder weather, but also a set of points would last an entire year, so I suspect the Chevy coil and ballast resistor must have pulled less amps through the points which about doubled point life.
