grandpa Love
Is there a way to search cl for a specific tractor? Nation wide. Hate searching one city at a time. Thanks
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]Is there a way to search cl for a specific tractor?[/i:654c4848f0][/b:654c4848f0]</font>"
You might consider using <a href="http://www.searchtempest.com/">SearchTempest</a>.
Hope this helps.
Go to searchtempest.com. Put in a zip code, select a distance, enter your tractor model, and see what you get. That should allow you to click again for more results. Generally I will do several searches using a zip code in the east and another in the Midwest, etc.
Use searchtempest and when you look, make sure it's looking in "farm and garden" and not in the general "for sale" section. Looking for anything with a common name like Ford or name that can get confused with other items like case requires a bit more work in setting the search parameters, but sticking with the farma nd garden section should help a lot.
There used to be a national CL search. We used it some but example you find an MM 670 you are in Vermont and its in Oregon!!!
You can do exactly what searchtempest does directly from Craigslist now.
Run your search on the local Craigslist. On the results page, look on the left side. Click "include nearby areas" and add cities to taste. This is exactly what Searchtempest does now since Craigslist enhanced their "include nearby areas" feature.
I highly recommend "bundle duplicates" too. Helps cut down on the idiot spammers who advertise their junk on every Craigslist within a 500 mile radius.
Craigslist is supposed to be for local face-to-face transactions, so they have always designed their site to discourage "national" searches. Unless you plan on showing up in person with cash in hand, be aware that some people may not want to deal with you.
