Aaron Ford
I recently purchased this car and am really hoping to be able to get it to the 50 years of Cougars at Carlisle. When I first got it running, there was a tick in the driver side valve cover that turned out to be number 5 exhaust pushrod eating into the rocker. The rocker appeared to be oiling normally. There was no evidence of what caused the failure. Fast forward a few months and the same rocker is completely dry. The pushrod is clear and the lifter looks normal (as far as I can tell without removing manifold). I am not above replacing the lifters which can be done with the motor in the car. I am also not above pulling the motor and replacing bearing shells, oil pump, rod nuts, lifters, and setting a performance cam. I would like to find what is causing this so that I can put this issue to bed. BTW, the pics show a shiny rocker arm on number 5 intake because I replaced the intake valve parts with new and moved the good rocker/pushrod from #5 intake to #5 exhaust as those parts were worn in. Any ideas?
